I have a family member's 99 Avalon with 32 K miles (yes, 32K) that has the A541E trans slipping when cold. It has been driven about 100 miles this past year. It will also not "creep" at idle when cold. When it is warm the there is no slipping, but shifts are a bit slow. There is also rumbling noise when cold. The trans fluid has never been changed , since this maintenance was base on mileage instead of time aging out the fluid. The fluid is up to level and is brown with some red . It does not smell burned.
How risky to drain and replace the fluid and not trash the trans ? The fluid is the Dex III ( obsolete , I know) The car is in pretty good shape and they'd like to keep the car for a few more years. If I do fluid change I would think a standard dex/merc and not the high mileage would be the best bet, since the HMs claim to have "extra cleaning agents" which may cause more problems.
