1999 GMC Sierra 1500 pitman arm bj torque spec
does anyone know the torque for the pitman arm ball joint nut for 1999 Sierra 1500 4x4. YouTube said 46ft lbs but for a 2500 Silverado
Arizona
46 ft-lbs is probably for the pitman arm nut that connects it to the relay rod.
The nut that connects the arm to the steering gear should be 184 ft-lbs.
Sounds correct for a 1500.
