I've done a fairly exhaustive search and have seen confident replies for opposite views of installation of the fluted pin, and round one with bush guide pin installation in the front brake calipers. Some say that the pin with the bush has and "L" on it and it that signifies it goes on the bottom. The fluted, or pin with 3 flats has a "G" on it, and those that say the one with the "L" goes on the bottom don't know what "G" means.
Incorrect pin install reportedly can cause shudder and Honda has released a TSB to switch the pins to fix it. I can't find the TSB.
The pins on the 4 cylinder cars screw directly into the caliper and bracket and don't have a separate retention bolt.
