Hello guys,
This is the 2nd UOA from my GMC Sierra. Here is the history of it as far as I know. I bought this truck in March 2011 from the original owner. It only had 75,000 on it and it is mint inside and out and was garaged all the time. The original owner only put 1,900 miles on it per year over the past 10 years so it sat a lot. When I bought it the intake manafold was leaking badly and I had my mechanic replace it and tune it up and replace all fluids, truck is 100% now and runs well.
After the intake gasket repair I drove it home and did another oil change with Castrol GTX 5w30 and also added Auto RX to help clean up things a bit not knowing how dirty it might be inside as the original owner did not have any maintenance records and the oil when I bought it looked DIRTY and black and was low on the dip stick but still in the safe zone.
Wear dropped a lot in this sample compaired to the 1st sample. I only drive this truck a couple times a month when I need a truck so it sits for a couple/few weeks at a time in my garage. It took me 14 months to get the 3,000 miles on this sample. I had a 1997 Tahoe with the same engine and I always used Castrol GTX and Blackstone stated it was the lowest wearing 350 V8 they had on file. Here is the details on the oil sample:
*82,185 miles on engine/truck
*3,000 miles on oil
*Oil in use from 79,164 to 82,185 miles and from 2/2012 to 4/2013.
*Castrol GTX 5w30 and is an Auto Rx flush cycle.
*Napa Gold oil filter.
*Napa Gold air filter is new.
*1st UOA 15oz of oil burned and this UOA 0 oil was burned or added.
1st number is 1st UOA and the 2nd number is this UOA. Both UOA's have 3,000 miles on them:
ALUMINUM 3/4
CHROMIUM 1/1
IRON 22/10
COPPER 104/51
LEAD 24/13
TIN 0/5
MOLYBDENUM 2/3
NICKEL 2/1
MANGANESE 1/1
SILVER 0/0
TITANIUM 1/0
POTASSIUM 44/34
BORON 8/7
SILICON 79/61
SODIUM 274/342
CALCIUM 1515/1784
MAGNESIUM 10/9
PHOSPHORUS 640/703
ZINC 686/843
BARIUM 0/0
SUS Viscosity @ 210 F 56.3/56.1
cSt viscosity @ 100 C 9.16/9.10
Flashpoint 415 F/420
Fuel 0.5
Antifreeze POS/POS
Water 0/0
Insolubles 0.3/0.3
TBN 4.2/2.9
I'm a little worried the intake may be leaking a little coolent in the oil still. What do you guys think? Also thinking Silicon is still high because of the intake repair and the gasket it still leaching into the oil a bit? What do you guys think of this sample and how is compairs to the 1st UOA? Think the engine is doing well and settling down? I just hope it is solid and will last me a long time! Thanks for any input! Picture of truck:
*3,000 miles on oil
ALUMINUM 3/4
CHROMIUM 1/1
IRON 22/10
COPPER 104/51
LEAD 24/13
TIN 0/5
MOLYBDENUM 2/3
NICKEL 2/1
MANGANESE 1/1
SILVER 0/0
TITANIUM 1/0
POTASSIUM 44/34
BORON 8/7
SILICON 79/61
SODIUM 274/342
CALCIUM 1515/1784
MAGNESIUM 10/9
PHOSPHORUS 640/703
ZINC 686/843
BARIUM 0/0
Fuel 0.5
Antifreeze POS/POS
Water 0/0
Insolubles 0.3/0.3
TBN 4.2/2.9
