This is the first time this engine used oil, no surprise, it was a 20wt. I'm thinking this is SM-rated oil, even though the bottle said "SL/GF-4" and was manufactured in Jan of '05. (I had a chance to buy 6 cases of this oil for $1.50/qt, but only bought 1/2 a case since I wasn't sure about having THAT much oil on hand. I shoulda just bought all of it and sold those Pep Boys coupons on eBay!
NVH was kept in check even moreso than M1 and MPG was up. I wanted to go much longer, but given the consumption, I figured change it early. This is a great oil, just not meant for these Saturns as oil consumption can be an in issue.
Topped off with something heavier at the 2200 mile mark: .75qt Catrol 10w-40HM SM.
Running conditions were VERY dusty with next to no rain this fall, thus the eleveated silicon.
Currently running Havoline 10w-30 HM.
code:
Year: 1996 1996 1996 1996 1996
Make: Saturn Saturn Saturn Saturn Saturn
Model: SL2 DOHC SL2 DOHC SL2 DOHC SL2 DOHC SL2 DOHC
Engine Size: 1.9L 4cyl 1.9L 4cyl 1.9L 4cyl 1.9L 4cyl 1.9L 4cyl
Total Mileage: 139,000 129,00 125,000 122,756 115,969
Fuel Type:
Fuel Additives: FP FP FP FP FP
Oil Use Interval: 2,900 3,000 1,740 2,881 2,900
Oil Type & Grade: PZ SM Synth PZ HM Pennzoil Shell RotellaT Mobil 1
Oil Type & Grade: 5w-20 10w-40 SM, dino Synth 10w-30
Oil Type & Grade: 15w-50
Oil Grade: 5w-30 5w-40 mix
Make-up Oil Added: .75 qt Catrol HM 10w-40 none none none none
Oil Additvies Used: LC LC LC LC LC
Crankcase Capacity: 4.5qts 4.5qts 4.5qts 4.5qts 4.5qts
Oil Filter: Mobil 1 ST Amsoil SD57 Amsoil SD57 Supertech
Notes: VERY DUSTY!! New PCV at 119K
Sample Date 10/29/2005 5/7/2005 3/4/2005 1/25/2005 10/2/2004
Element PPM PPM PPM
ALUMINUM 2 1 2 1 2
CHROMIUM 1 0 0 0 0
IRON 3 3 3 4 4
COPPER 1 2 1 2 3
LEAD 0 1 1 1 0
TIN 0 0 0 0 1
MOLYBDENUM 54 89 120 4 47
NICKEL 0 0 0 0 0
MANGANESE 0 0 0 1 0
SILVER 0 0 0 0 0
TITANIUM 0 0 0 0 0
POTASSIUM 0 1 0 0 0
BORON 11 11 28 11 111
SILICON 8 4 4 4 3
SODIUM 1 1 1 2 3
CALCIUM 2069 1697 1323 2699 2705
MAGNESIUM 8 6 11 13 11
PHOSPHORUS 625 746 508 909 820
ZINC 711 894 645 1006 925
BARIUM 0 0 0 0 0
cST @100c
SUS 210F 55 64.5 56.1 69.8 64.1
Flashpoint F 390 385 370 380 370
Fuel %
AntiFreeze % 0 0 0 0 0
Water % 0 0 0 0 0
Insolubles % 0.4 0.3 0.5 0.3 0.4
