Quick question, what would cause my 1995 F.T 3.8L Automatic 96K miles to feel sluggish when warm? Not even like sluggish, because if you give 100% throttle, the car is fast, and acts 100% normal. When the car is cold, It runs great, and will run great for the whole trip 25+ miles one way, but it seems as when you turn off the car and restart it, then it runs sluggish right from there. Is there any sensors that i can clean/check/replace?
Give 100% throttle, and you can spin tires.
If you give 75% throttle, the car will rev high, and it feels as if i lost 4 cylinders.
Give it 50% throttle, and the car will almost be faster then giving 75%, then if you letup to 25%, The car then feels the fastest out of the 3..
Does not happen all the time, It is totally temperature dependent. 70F+, City driving makes it seem the worse.
Transmission is perfect, Just changed fluid and filter twice.
I use Pennzoil Platinum 5W30 and a Fl-400s Filter.
Ran cleaner with the gas.
Thanks!
