I have a leak at the reservoir where the high pressure hose fitting is. I replaced the high pressure hose thinking that was leaking but it wasn't. This has been weeping for some time but now its marking the driveway. I know there are seal kits, but my question is, is the seal for this fitting, which does not come with the pressure hose supposed to be flat or more like an O-ring? I don't know if the seal kits you can buy has the correct O-ring or seal for the reservoir.
The fitting in question. It has a black seal against the reservoir.
20170706_212558 by JOHN, on Flickr
Leak from the bottom
20170706_212652 by JOHN, on Flickr20170706_212541 by JOHN, on Flickr
