1994 Pontiac Grand Am 3.1L V6 automatic
GM 5W30 API SL
1 bottle of AutoRx added at beginning of OCI
3/4 Highway driving
AC Delco oil filter
Sample taken Jan-15-2005
1,765 miles on oil - 1 month
146,963 miles on car
Blackstone did the current UOA. OAI did the other UOAs. I'm going to start using Blackstone I believe.
1st #: Current
2nd #: 12,504 milles S2K 0W30
3rd #: 18,331 miles S2K 0W30
Iron - 5/37/44
Chromium - 0/2/3
Lead - 1/21/23
Copper - 1/20/17
Tin - 0/0/0/0
Aluminum - 1/12/12
Nickel - 0/0/0
Silver - 0/0/0
Silicon - 8/76/144 abnormal
Boron - 3/31/25
Sodium - 15/245 abnormal/74 abnormal/
Manganese - 0/NA/NA
Magnesium - 47/874/457
Calcium - 908/2804/1796
Barium - 0/0/0
Phosphorus - 392/1071/882
Zinc - 423/1224/1268
Molybdenum - 0/14/13
Titanium - 0/0/0
Vanadium - NA/0/0
Potassium - 0/35 abnormal/55 abnormal
Fuel <0.5/<1/<1
Viscosity: 9.49 cst/17.87 cst abnormal /16.80 cSt - abnormal
Water - 0.0/0/0%
Glycol - 0.0/NEG/NEG
TBN - 3.3/3.38/3.0
Oxidation - NA/13.0/14.0
Nitration - NA/10.0/12.0
Insolubles - 0.4/NA/NA
Flashpoint - 400°F/NA/NA
Blackstone's comments: Wear was very low in this sample from your Grand Am, which makes since considering you only ran this oil 1765 miles. The universal averages shows typical wear from this type of engine after 3800 miles on the oil. The TBN read 3.3, so the oil still contains some active additive. We consider anything from 1.0 and lower to be too low. Note the additives in your sample. They appear to be low, though we didn't find any cause for it in your oil like moisture, fuel, or coolant. Maybe they have been diluted by the AutoRx. Use 1750 miles again and check back.
UOA history: newest to oldest with Castrol GTX http://theoildrop.server101.com/ubb/ultimatebb.php?ubb=get_topic;f=3;t=001379
http://theoildrop.server101.com/cgi/ultimatebb.cgi?ubb=get_topic&f=3&t=001378#000002
http://theoildrop.server101.com/cgi/ultimatebb.cgi?ubb=get_topic&f=3&t=001377#000000
Added 5 pack of GM cooling tabs 1,152 miles into OCI at 146,350 miles. At least the sodium & potassium have went away. Yeah! Oil was changed at sampling with GM 5W30 SL and a new AC Delco oil filter. Comments, fire away!
