I'll (try to) keep it brief. The following questions are regarding a 1994 Dodge 1500 pickup with the 5.2L V8 (318 C.I.) engine- 2WD. It also has the automatic transmission. Since the truck is somewhat tired, it needs some servicing done to it.
1. The manual specifies "Mopar ATF Plus- Transmission fluid type 7176" for the transmission. Since I have some (20qts) of Dex. III laying around in the garage, my question to you is whether this fluid is interchangable with the Mopar ATF. What is 7176 anyways? The manual specifies that Dex II is alright if nothing else is available, but the shifting might be "unsatisfactory". Is this a ploy to get you to buy their fluid, or is it realy different?
2. For the rear axle, the manual specifies all sorts of different weights, to the point where it's very confusing. It also mentions a "Mopar Hypoid Lubricant" as the recommended fluid. I have 3qts of GMs axle lubricant in the garage. It doesn't say what weight it is, but it says that it's approved for their Torsen diffs. Is this oil good enough for the Dodge truck, or should I pick up something else? What weight shoul I use?
Any quality message boards for Dodge truck fanatics?
Thanks,
Paul
Thanks,
Paul
