Originally Posted By: J_Myler
So that's all I have to do? I was told you have to replace them.
Easiest way to check is to fully compress the caliper piston while the caliper is still mounted on the bracket. Then slide the caliper back and forth-- it should be smooth and effortless.
Caliper slide pin bolts DO need to be replaced on some applications. Check the Factory Service Manual for your vehicle. On many VWs, they are stretch bolts (IIRC) and they must be replaced at every brake job.
Also, be sure to clean and adjust your rear brakes. This is VERY important if you have drum brakes in the rear.
