According to Amazon, my Camaro takes the shorty filter - EX: AC Delco PF454, Puro L/PL/PSL15313, Fram PH/TG/XG30, KN-2002, M1-111, RP-10-454... etc.
But from what I've researched, my Camaro has plenty of room to fit the larger/longer versions of these filters - EX: AC Delco PF1218, Puro L/PL/PSL34631, Fram PH/XG5, KN-3002, M1-302, RP-30-1218...
(And this isn't even considering the wide array of Wix filters that fit on Chevy small-blocks)...
So my questions are:
1. Can I use the longer filters; doesn't the 305 have enough clearance for the longer ones?
2. If yes, what are your opinions on which filter you would prefer on my 305 TBI?
3. If no - (that is to say, if I'm better off using the shorties) - again, what are you're opinions on filter preference?
All the above being said...
As you see I didn't mention Wix filters in my examples: that is not because I dislike Wix. In fact, I really, really like Wix. But, with so many 13/16" threaded Wix filters (that *could* fit my Camaro), I wasn't about to list them all. Ergo, feel free to suggest Wix, or not, if you prefer other brands.
P.S.
One last question: The PF1218 and PF2232 are nearly one in the same, besides that the PF2232 has a bypass...
Does my Camaro's engine have the internal bypass, so that (assuming I may use the longer filters), I can use the PF1218 [and/or other filters w/o a bypass]?
~ Triton
P.S.
~ Triton
