Hello guys,
I just want to share my oil analysis as I just received it from Black Stone lab.
Note that I purchased the car last May (2016) and an oil change has been done without knowing what is oil nor its grade. As I rarely use the car, I put 2000 miles since I bought it last year. I decide to change the oil as I noticed the oil turned very dark black even though I put only 2k miles. I also noticed that the engine is burning oil since there is no sign of leaks at all.
I would like to hear your observations and comments.
Current fill VWB5w30 + Wix gold filter
Code:
Thanks for the notes. We're not sure exactly why your oil level is low, but there is some
higher wear here. Aluminum shows piston wear and iron is from steel parts. Neither one is really high
enough to call a definite problem though, so we'll just wait and see how they look next time. You mentioned
wanting to change the oil every 3,000-5,000 miles. We'd start with 3,000 miles on the next oil and then go
from there. The TBN is 3.1 showing active additive left. The viscosity is in the 5W/20 and air and oil filtration
look good.
OIL Unknown [5w20 as Blackstone said]
MILES IN USE 2k [1 YR]
MILES 68k
SAMPLE TAKEN 05/14/2017
ALUMINUM 12
CHROMIUM 3
IRON 54
COPPER 2
LEAD 12
TITANIUM 2
MOLYBDENUM 46
NICKEL 0
MANGANESE 9
SILVER 0
TITANIUM 1
POTASSIUM 1
BORON 28
SILICON 12
SODIUM 127
CALCIUM 2539
MAGNESIUM 41
PHOSPHORUS 951
ZINC 1015
BARIUM 0
Fuel %
Antifreeze % 0.0
INSOLUBLES 0.4
WATER 0
FLASHPOINT ºF 390
SUS VIS 210ºF 54.5
cSt @ 100ºC 8.62
TBN 3.1
Code:
look good.
MILES 68k
ALUMINUM 12
CHROMIUM 3
IRON 54
COPPER 2
LEAD 12
TITANIUM 2
MOLYBDENUM 46
NICKEL 0
MANGANESE 9
SILVER 0
TITANIUM 1
POTASSIUM 1
BORON 28
SILICON 12
SODIUM 127
CALCIUM 2539
MAGNESIUM 41
PHOSPHORUS 951
ZINC 1015
BARIUM 0
Fuel %
Antifreeze % 0.0
INSOLUBLES 0.4
WATER 0
FLASHPOINT ºF 390
SUS VIS 210ºF 54.5
cSt @ 100ºC 8.62
TBN 3.1
