You don't need zinc, what you think you need is phosphorous, which is the AW component, combined with zinc to form ZDDP. Phosphorous is what was restricted for the energy conserving oils in xW-30 and lower starting with API SM.
I wouldn't run anything made by Lucas if you paid me. Their marketing of their hot garbage "Oil Stabilizer" products is appalling.
The 351W isn't an application that's overly hard on oil, and if you've got the factory broomstick cam, that applies doubly. I'd personally run M1 0W-40 in it (or Delvac 1 5W-40), but if that's out of the budget and you don't need the 5W-xx or 10W-xx Winter grade in your climate, I'd grab some Delvac or Rotella 15W-40.
