Not sure if any of it was staged though.
Sieves don't smoke. They leak.She smokes like a sieve.
She's leaking smoke!Sieves don't smoke. They leak.![]()
I don't buy into it. After that many years, I wouldn't believe that crankshaft would even rotate.
Can you imagine? LOLThe Martin Bros would have an LS crate motor in it a week after paint![]()
i think the starter was moving backwards
is a 1929 gmc positive ground? most american cars were back in the day
He gets it to start after the 3rd or 4th crank with a ratchet and it stays running after a couple more? Without even working the throttle? That never happens even on 60's car sitting a few months.Weird thing for me was that he got the starter working, but then continued to crank it by hand. Also, he was spinning it over one way with the fan, then the other way with the ratchet...
I assume there was a lot more farting around with it before that video sequence, he even alludes to that being the case. He was also trying to start it on brake kleen for ages there too. I've used propane, which works too.He gets it to start after the 3rd or 4th crank with a ratchet and it stays running after a couple more? Without even working the throttle? That never happens even on 60's car sitting a few months.
