19 hp Kawasaki oil question
ohio
I did the reccomended 8 hour break in on a new 19 hp Kaw in a zero turn and was going to use synthetic for the oil change. I was going to use 10 30 Mobil 1 until I read that it was api sm and the engine manufacturer stated api sf sl etc.., Thought about going to Amsoil ASE 10 30 sae 30 because it meets the manufacturers specs. Kawasaki says they do not reccomend synthetic oil in their engines. Anybody with any good reccomendations as to which way I should go?
I had a 23HP Kawi on an Exmark ZTR. Trust me the oil is the last thing you need to worry about, if it is dusty at all get ready to change the air filters. Once they get a little dust in there they are never the same. I tapped out my air filters every other day and changed them every other week. (It was used on average 20 hours a week) Also I mowed some really [censored] industrial parks that had a lot of bare spots with sand.
But I would say any quality conventional or synthetic will do the trick. I used Havoline Syn in mine quite a bit. I also believe that a 10-30 is the best weight for them although I don't remember what the manufacturers recommendation was.
Called the manufacturer and the guy that answered the phone in the technical department gave me a canned speech about them not doing any testing with synthetic, blah blah blah. The same thing Harley Davidson used to do for years until everyone started to switch from the MOCO stuff to synthetic because it made an air cooled motor run cooler etc.., And then they came out with Syn 3 and the reccomend it for everything on their bikes.
Run the ASE 10W30 from Amsoil. After clients of mine have run it in a few different applications, and it has displayed excellent sheer resistance, oxidation resistance and wear control I can't recommend anything else to beat it.
I think the ASE 10 30 Amsoil seems to make the most sense it meets all of the manufacturers ratings and it is syn oil. I was never a big believer in syn oil until I put Mobil 1 in my wifes new v6 Accord at the first oil change upon my neighbors reccomendation. My neighbor who is an aircraft mechanic will not run anything but synthetic in anything he owns and has used synthetic since the 70's.
My dad ran Mobil 1 10w30 in all kinds of OPE engines that never made any mention of synthetic oil, many of which said only to use SAE30.
If the API classification on the oil container is the same, or later in the alphabet when compared to the OE, you will be fine.
Sure, I have had experience with Mobil 1 in OPE only, but I'm confident that the Amsoil ASE is a great product. I have used some other Amsoil products in different applications, and they were great.
Rudyjr,
I went thru your exact motions last year with my new workplace Exmark with 23 hp KAW. Same canned speech from their tech. guy, except he said even SM oil is suitable.
If you wish to ponder this more, visit lawnsite.com for the "professional's" view. There, you will get more anecdotal stories of "My (insert: self, friend, father, etc.) used (insert: brand x,y,z, weight 10Weverything) and it ran for 8 gazzion hours trouble free. There is no "best" answer.
Generalizing, KAW still leans towards 30 wt.("maybe" consumption with 10w30) and Kohler Command recommends 10W30 due to its lifters.
We have had heated debate here wondering if SM additive levels are suitable for air cooled engines. Choose your side/belief.
Exmark (FAQ and service tips) says to break in your engine with dino (another debate...any where from 0 hours to 250 hours(Exmark)).
I chose to use Rotella 30W (SJ) for the first 100 hours (I'm chicken/warranty) and if I switch to synthetic it will be Amsoil ASE or ASD so I don't have to ponder 30 vs. 10W30. I think the ASE is a great choice for those "on the fence".
Everyone "seems" to agree that the one thing synthetic really does is reduce operating heat of air cooled engines. Less wear, extended drains, etc.. are still debated. Exmark as well as all auto MFG. recommend not changing OCI intervals with synthetic.....CYA I imagine.
Good Luck......are you "by the book" or "seat of the pants"....that is what will guide your decision.
From the EXmark site service tips:
"most engine manufacturers do not recommend the use of synthetic oils. The proper petroleum-based oil lubricates the engine adequately."
Odd......very odd for this day and age. Pablo, please investigate and report back!
I have a 13 hp Kawi "KAI" in my SCAG and IIRC they advise against the use of syn oil because there may be an increase in oil consumption. I run RP MaxCycle 10w30 in my engine and the oil level hasn't budged.
I use Mobil 1 Turbo Diesel Truck 5w40 in my JD (kawasaki 18HP twin). I was having a bit of an issue with oil pressure at idle with the conventional oil. The syn oil clearly works better.
Chris
Well I put Amzoil ASE in it. I have become a believer in Synthetic oil from what I have seen and heard from people I know, some mechanics and just plain tinkerers. I know for a fact it will make a Harley Davidson run cooler. And heat is a big problem in those engines. I still follow the old 3500 mile interval on my wifes car with Mobil 1 in the crankcase. So if anything I am too picky about oil changes I suppose.
