The MIT paper got me thinking that the higher SAE mono-grades have more VI between 120C and 180C than the lighter grades have.
It would be interesting to have a high temperature VI for the
application of HTHS instead of just 40C to 100C.
When comparing SAE 10W to SAE 20, the specification that I looked at was the flash point.
The SAE 20 being much higher at 231C, suggesting a better resistance to heat than 10W.
For the application of HTHS at the ring reversal point, I believe that the higher the flash point the better.
Temporary shear at the ring reversal point I think is undesirable as the lubricant is reduced to it's base-oil viscosity.
By blending SAE 20 instead of a reduced percentage of 10W with 15W40 plays into the notion that a higher base-oil viscosity is better.
We still have the VII in the 15W40, but that grade has proven to be hard to beat, and there is no point in throwing the baby out
with the bath water.
I don't want permanent shear at the end of the oil's service life to go below what a 0W40 would, taking the history of that grade into account.
The stay in grade bar had to be raised to make 0W40 work, and if I remember correctly, it was you who posted the link 12 or 13 years ago.
To raise the HTHS to 3.7-3.9 blending SAE 30 with 15W40 is an option that results in a 15W40 that plays at the low-end of the SAE 40 scale.
