Sadly, refrigerators and other big appliances have become disposable; IOW the components (designed to prematurely, whether on purpose or just by use of incredibly fragile plastic parts) fail are too hard/expensive to fix forcing consumers to repetitively buy new. This creates a forced consumption ecosystem of expensive "durable" (what a laugh) goods. Expect EVs to be built on this same business model by the way.
I own a house and a rental. Both had $2000 French Door units. Rental had the compressor fail at year 4 or so, outside of warranty. It cost almost as much to fix it as a new fridge. My house fridge compressor failed at year 3 or so. It was also nearly the cost of a new fridge to fix, but thankfully this fridge has a longer warranty so the repair was barely inside the warranty window.
My advice when it comes to refrigerators in particular, you want LOW TECH, NO WATER DISPENSER or door ICE MAKER and ideally FREE, and if you do buy one, look at the warranty and get the longest warranty on the system and especially the compressor. First, look what's available locally for FREE. Get a FREE one in advance in put it in the garage as an emergency backup so you are not caught without a fridge if yours fails. Get a good FREE used one off the local FB marketplace or craigslist. Ideally, a low-tech model many years old. I have a free one in the garage that meets that criteria, and it works like champ. If you MUST buy a "new" one, go to a appliance scratch and dent sale or aisle where you'll save a lot of money. And get the longest warranty on the compressor, ideally at least 5 years and 10 is excellent. The advice against water/ice in the system is that when they fail, and they do, the water damage can be extensive. The lower the tech, the better IMO. You don't need a lot of fancy - you just need a reliable cooling unit.
