12v/120AC Inverters that can handle low voltage with deep cycle batteries...?
I just bought a Marine deep cycle Optima blue battery D34M to use with my 2 inverters. Both have low voltage shut down around 10.5 - 10.9 volts. Inverter #1 is an older TripLite 500 watt and the other is a Costco 400 watt with a fairly handy dc voltage input toggle/wattage/receptacle voltage display. It start chirping when input voltage drifts down to even 11.3 volts.
I'm running these set up at probably 500 to 700 watts combined output. I was expecting the battery to hold out longer than 40 minutes before I get low voltage?
Maybe I'm expecting too much but I'm thinking these inverters are geared more towards standard automotive batteries which don't like to be discharged below 11 volts.
Is there an inverter that will up regulate specifically for use with deep cycle or is a voltage drop down to 11 volts already a huge amount of discharged capacity?
Any help much appreciated
