12 Impreza 2.0L (FB20), AMSOIL ASM 0W-20, 6503 mi.
Virginia, USA
Html:
OIL AMSOIL ASM 0W-20
TOP-OFF OIL None - No loss.
FILTER Mobil1 M1-104
SUMP CAPACTIY 5.5 QT
MILES IN USE 6.5K
MILES 73.1K
SAMPLE TAKEN 08/18/2014
LAB: Oil Analyzers Inc.
Wear Metals (ppm):
ALUMINUM 0
CHROMIUM 0
IRON 5
COPPER 1
LEAD 1
TIN 0
CADMIUM 0
SILVER 0
VANADIUM 0
NICKEL 0
Contaminant Metals (ppm):
SILICON 25
SODIUM 6
POTASSIUM 0
Multi-Source Metals (ppm):
TITANIUM 0
MOLYBDENUM 157
ANTIMONY 1
MANGANESE 0
LITHIUM 0
BORON 96
Additive Metals (ppm):
CALCIUM 3729
MAGNESIUM 44
PHOSPHORUS 716
ZINC 803
BARIUM 0
Contaminants:
FUEL DILUTION
SOOT
WATER
Fluid Properties:
cSt @ 100 C 9.1
TBN 6.27
OXIDATION 51 abs/cm
NITRATION 11 abs/0.1mm
This was my first UOA so to play it safe I drew 1 qt. at the time of sample and replaced it with a fresh quart of AMSOIL ASM 0W-20 to replenish additives and TBN. Fluid and filter are still in use.
Silicon is a little higher than I'd like to see.
Other than that, wow fantastic report! I'd check again at 10-12K.
Yup, looks good and can go further.
Maybe so...I'd check filtration.
