Experience counts, but you need to qualify it.
There were oil pump modifications, bearing changes, etc., to the marine engines he discussed. Also, marine engines are run at or close to maximum output for extended periods. The wave action and bumping around can create the conditions for the oil to be whipped up by the crankshaft. Thicker oil may mitigate these issues for that application.
Few cars ever are used in this manner. Many never get oil very hot either. Personally, I would worry about oil pumps driven off geared extentions to distributors or camshafts, like older American V-8s. The gears or pumps may not last under the stress of high viscosity oils.
Also, LS1s in Australia may be used in areas where there are no speed limits while at the same time being very hot (40C).
In Singapore, your manufacturer oil viscosity recommendations aren't swayed by government testing rules as they in the US (only the viscosity used in the certification testing is allowed as "recommended"). I would stick to that.
