10W-40 wimpy, 15W-40 tough
Missouri
The reputation is that 10W-40 oils break down quickly. Some think the 30 point viscosity spread requires greater VIs, which shear quickly, losing viscosity. 15W-40 oils get high praise for resistance to shearing and breakdown. They have a 25 point viscosity spread, 5 less than 10W-40. Several questions: Is there really that much difference between these oils? Does the additional VIs required to get 5 more points make the 10W-40 dramatically more susceptable to shearing? Is the additive package that much more robust in 15W-40? Is the main difference between 10W-40 and 15W-50 greater amounts of ZDDP in 15W-50? Is the bad reputation of 10W-40 based on older oils, and are modern 10W-40's very good like most oils. Why does 10W-40 have such a bad reputation?
Canada
15W-40 HDEO's are much 'tougher' than 10W-40 PCMO's. 15W-40's use a much heavier base oil, so they ofter have a HT/HS of 3.5 or better, as do 'A3' euro oils. PCMO 10W-40's CAN have a high HT/HS value, but they are only required to have the same as a 30-weight, or 2.9. (Not 100% sure I have that right, I read something like that by one of our more knowledgable members once...) 15W-40 do usually have a much stronger add-pack in them, to take the abuse of diesel service - they have higher Calcium/Zinc/Phiosphorus amounts, and a higher TBN value. In general, most PCMO 10W-40's are just 'SM' rated, and have the same add-pack as 5W-30/10W-30's. With that said, there is nothing wrong at all with modern 10W-40's. They are made with the same quality basestocks that the 30-weights are, and a modern 10W-40 and 5W-30 often have the same VI. The bad rep 10W-40's have is mainly from the 1970's, when group I basestocks were used, and a lot more viscosity index improvers had to be used to make the spread. These VII's were also poorer quality, and reacted badly to heat and broke down, causing sludge.
Central Washington
Yup. a 10W40 is only required to meet the HT/HS of a xW30. It could be built tough, but most PCMOs are not built that way. I thought I read somewhere they would be changing that so 10W40 has to meet the rest of the 40 grade soon, but Im not quite sure where I read it, or if its true.
California, USA
That is correct. Here is a link to SAE J-300. http://www.finalube.com/reference_material/SAE_Viscosity_Grades_For_Engine_Oils.htm I think the lower HTHS is how M1 0W-40 can say "Energy Conserving" in the "donut".
