The volume of the oil output to the bearings is determined by the size of the bearing oil passages, the actual viscosity of the oil at temperature, and the pressure. With everything else staying the same, the high volume oil pump will just dump more oil back to the sump by forcing the pressure control valve wider open.
An engine built with larger bearing clearances is the one that benefits from the high volume pump.
Ken
