Intake Valve Deposits
A series of 5,000-mile tests were run on an FFV using varied mixtures of ethanol and gasoline. The results showed that with no additive present, ethanol impacts the amount of intake valve deposits formed in the engine. At lower levels of ethanol such as E10, intake valve deposits actually increase to higher levels than in gasoline alone. However, in blends with higher levels of ethanol, the level of intake valve deposits actually decreases to the level found in gasoline, or even lower. Gasoline and E10 blends are commonly treated to reduce these deposits for improved emissions, performance and fuel economy. E85, even with its lower deposit impact, should still be treated and does not normally contain sufficient levels of deposit-control additives (Figure 1).
