10-day review - 2025 Ford Bronco Sport
OVERKILL
$100 Site Donor 2021
Ontario, Canada
Was recently in NC for a little over a week and we had a bright blue Ford Bronco Sport as our rental. Looked like this (my apologies for not taking pictures):
Impressions from myself and the others that drove it? Not great.
- Storage room in the back is decent, though the glass/door opening buttons (which trigger manual operation of both, neither are electric) are not well labelled and people opened the wrong one a few times.
- Interior is a sea of cheap plastic. The "tablet" bolted to the dash looks gaudy and is trimmed in a bezel that looks like it's meant to be on a kid's toy from Walmart for $49.99.
- Button bar, which you are motivated to stab the S/S disable button on after the first time it engages, is in fact a one-piece bar, not buttons, so the entire thing deflects oddly when you press on it, which does not work to improve upon the impression of cheapness.
- Wireless car charger worked well, and is placed in a decent location
- Gauge cluster is better than the tablet, gauges are clear and reasonably well laid-out
- Seats are acceptable. Not much in the way of bolstering, but the materials seem durable. They are not great, but they don't make your bum numb.
- Sound deadening is limited. This wouldn't be a big issue at this price point except that the engine sounds like a diesel, particularly when cold, so the noise coming through isn't the pleasant song of a spritely power plant, but a raucous barrage of noise, while motivation provided matches the theme; is far from athletic.
- Ride and handling are about what you'd expect. Not luxurious, but not awful. Steering behaviour is good, body roll is minimal, but, due to the engine, that's where any semblance of "sporty" ends, which makes the "Drive Modes" knob mostly about suspension and tip-in, as even in "Sport" the engine makes it clear that this really isn't what you are getting.
Yes, "does not inspire confidence" is a good description.
Oil pump belts are fantastic on a dry sump application in a racecar when you can see it and say "o look that belt looks like it needs to be replaced, lets replace it before it breaks and chunks our expensive race engine." On a street car when you have to take half the car apart to get to it, see 3.0 Babymax, it is not a good idea I don't care what any engineer says or thinks.
I can’t stand the “laptop glued onto the dashboard” either, on any car I’ve seen it on.
Also not a fan. I get why they do it, but it seems like a huge afterthought. That and I would live in constant fear of breaking it. At least the giant screen on the Super Dutys is still built into the dash.
I think the one good thing about the "tacked on" screens is that they aren't really needed, HVAC is real buttons, and even the radio can usually have the basics controlled from the steering wheel.
I kind of consider these to be an econobox SUV and not the off road monsters folks dress them up to be. I know someone who has a Raptor version. Looks super cool. But seems more showy than capable IMO.
There are 2 different Broncos which makes it really difficult on us parts people. The Bronco Sport that @OVERKILL rented is based on the Escape. The Bronco is based on the Ranger platform and is body on frame with a longitudinal engine layout.
The I3 EB has a chain now last I checked.
Hopefully that is new new, because I just checked on a 2025 Bronco Sport listing and it still shows a belt. Ford uses belt and chain interchangeably in their descriptions, but the picture shows a cog belt.
I definitely bow to your info.
Now I'm questioning where the #@$ I came up with that information....stupid brain. Maybe I was thinking of the timing chain? Did those used to be belts on the I3's?
All the more reason to upgrade to the 2.0, it should be gear driven like the 2.3 in my Ranger.
bdcardinal:
1.5L 3 cylinder “Dragon” engine found in the Bronco Sport & Escape has a single timing chain. Has been that way since about the ‘21 model year. The previous 1.0L 3 cylinder had a timing belt. I am 99% sure. My son has a ‘21 Ford Escape 3 cylinder. It is a bit “agricultural” for my taste, but is nonetheless reliable.
Ogatti Auto Parts website lists a 6 piece timing chain kit available for the 1.5L for about $150.
I think that 1.5L has an oil pump drive belt. I am not certain if that is a replaceable maintenance item.
