This is true, a 1 second pour into the oil fill should be enough.quote:
Originally posted by TooSlick:
This is like trying to wash a car by dumping a bucket of soapy water over the roof and not rinsing it. But if it makes you feel good, knock yourself out.![]()
Vette-brother, You should at least jack the rear of the car to level or best would be to raise the rear higher to get that old oil out. Mine takes 7 qts to get to the full line when I get the rear up higher then the front.quote:
Originally posted by Patman:
I pour more than one quart of fresh oil in my Corvette at the end of the oil change, because the design of my oil pan leaves 1/2 quart of oil in the back of the pan with the car up on ramps. So by pouring in a lot of new oil I hope to flush out a bit more of that trapped oil.
I'm not into the whole "jacking up the rear" thing. Sorry, just too dangerous for me. Plus my big jack is at my parent's house, I don't have room for it here.quote:
I drained with the front on ramps and the rear on the ground. Waited for the oil to stop.
Placed a jar ontop of my enclosed oil pan. Jack rear to even with the front and got 1/2 qt more out. Waited for oil to just about stop draining.
Jacked rear higher then front and almost finished filling the quart jar.
So its possible that you may be leaving an entire quart of old oil in your car.
How many quarts does it take for you to be on the full line?
Sorry to highjack your thread pmwalter.![]()
I never drain mine off after the track overfill. Like you said its not going to hurt anything.quote:
I think it takes me about 6.5L to show full on the stick, although I'm not 100% sure since I just shove in an even 7L to keep it simple. That puts the level above the full mark (but as you know, the LS1/LS6 can handle being overfilled)
