ARX will only help you with the cyclinderical seals. As in crank and cam seals. I would not expect to see the leaks in these areas until well into the rinse phase, or second rinse phase, if dual applications are needed. With the rising cost of fuel car purchases are much tougher to afford. Glad to see you taking care of the current equipment.
