Yes, but probably not worth it's cost.
Try one of the 15W-40 dual-rated diesel lubes. Let us know how it works for you.
Ken
Ken
Hold on... You're saying the Saturn wasn't designed to run a "heavy cold" 10W-x oil??? I might agree if you made this comment in regards to straight 50wt racing oil, but not when we're considering today's multi-vis, winter-rated consumer oils.quote:
Originally posted by manualman:
Don't go using that heavy cold wt oil in your Saturn. The oil passages to the timing chain in the 1.9 are TINY. You'll oil starve the chain until it warms up. And at your mileage, that chain needs all the oil it can get.
Shame on you who make recommendations about cars you haven't researched.
Ted,quote:
Originally posted by TooSlick:
Matt,
The good news is that if you are adding a quart of Amsoil every 2000 miles, you can run the same batch of oil almost indefinitely and just change oil filters every 7500 miles. All this fresh oil is diluting any contaminents and replenishing the additive package in the oil. The oil that is leaking into the combustion chamber is taking any contaminents suspended in the oil with it, and these flash off as well. I would use a premium oil filter like the Amsoil or Mobil 1 filter to keep the oil as clean as possible.
If I was running the Amsoil 10w-40 in this particular engine, I'd just do an oil analysis annually and never drain the crankcase unless the analysis indicated it was necessary.
Amsoil has the lowest evaporation rate of the three oils you have listed, so it should give you the lowest oil consumption. My second choice would be Delvac 1, 5w-40 for this application ....
If you have any further questions, please contact me off-line ....
Ted
