Hello, it's been a while since I've been active on this form. I'll get right to it then. I'm planing a 1,000 mile one way or so vacation to the Colorado Rockies and Custer/Badlands South Dakota area this summer. I've been religiously using GC 0W30 for 6 years now. While towing a 3,000lb single axle travel trailer through Yellowstone in 2013 I experienced a higher than expected coolant temp of 220* or so traversing the north entrance of Yellowstone. I'm expecting the same climbs in Colorado this year in late June with a heaver 5,000lb travel trailer pulled by my 2000 Silverado EC Z71 with the 5.3L and HD tow setup. I'm thinking of using the 0W40 Euro Edge in my sump for this springs annual oil change. I will also be installing a larger 34" radiator with the integrated engine oil cooler prior to the pull. So question is which weight oil would be best for my one year oil change interval? Transmission has a larger stacked plate cooler running Royal Purple Max ATF. All other oils are Mobil 1 of RP synthetic.
