Originally Posted By: MichiganMadMan
You are going to need a +1 quart for the change, hope you don't mind having a "growler" around to make up the difference.
There are a lot of people with high oil consumption on the FB equipped Foresters, so check your oil at every fill up (you probably do anyway, being a BITOG memeber). I have found mine to be hyper-sensitive to inclination angle. I can "gain" a quart by turning mine around at the same gas pump.
You might want to mention the potential oil consumption to your wife before the engine is two quarts low in a spring snowstorm, across town from you.
Yeah I don't mind. I typically stock up on 30-50 quarts of oil at a time, so I don't have to fiddle with buying it.
I've read about the FB25 consumption problems, and thought that was the 2011 models, and most if they had the problem got new rings. I'm still keeping an eye on it though
Looking through the service records, I don't see any notes about it being low on oil.
Anyone messed with the Castrol 0w20?
