Ok, but what would be the route to take from here.
Why not 5w30 and sleep easy? There is no concern for the bearings in your application IMO, even on a 20grade. HV pump further enables superior
flow with 20/30 grade, and less pressure drop throughout the oil galleries- meaning less pressure drop between the pump outlet and the actual orifice. That is a very real concern and I think you should consider the following
[small digression]
Oil flow is paramount. Let's discuss what happens to oil after the oil pump with different viscosities. (starts boring, but leads somewhere
) All oil reaching the rod bearings must travel through a labyrinth of oil passages within the engine. Right off the pump outlet, the oil enters the first half of the main gallery. Being a well-sized artery, we expect a minimal pressure drop. Next, oil is led into the filter, depending on design, we'll see a moderate pressure drop- and an oil cooler will again cause a pressure drop. After the oil filter, is where most OP gauge sender units are located. The pressure you see at this point has already dropped via the filter (and cooler if equipped). So it should be noteworthy that there will always be a discrepancy between the pressures that the bypass valve sees, and your OP gauge.
Also, again another reason that I explicitly implicate the bypass as the cause of your secondary pressure drop, and not cavitation, is simply due to the fact that there is so much resistance to flow on the supply end, that it would be almost ludicrous to think that the pickup tube/screen could be more of an impedance than the filter, cooler, and oil galleries. Trust me, the delivery side is not accepting more oil than the pickup can supply! Especially not a high viscosity oil like the 40, which would flow even less to the delivery side, and even more through the bypass...... causing it to enter a higher relief zone in the upper RPMs where you notice the PSIG drop.
But back on topic, after the filter, oil enters the main gallery- the manifold of which all things are fed.
Depending on engine design, under-piston oil squirters are fed directly off of the main gallery. As this can severely drop pressure to all other feeds, they are sometimes valved by springs, where they open only above a certain PSI. I'm not sure if SBCs are commonly equipped with piston oil squirters. Anyway, other feeds directly off the main gallery are to the head(s), to the VVT, to the turbo, and to the main bearings.
Now for the good stuff, let's focus on the bearings. The mains get fed right off the main gallery, pressure drop is minimal. What about the rods? Well, the only way they can be fed is through the crankshaft. The oil passages in the crankshaft are a pressure drop nightmare. Not only does the feed have to enter a constantly rotating orifice at the main bearing, which is already leaking volume from it's clearance, but the already pressure-dropped feed into the crankshaft via the mains must again find it's way through small, angularly drilled passages
within the crank. Getting to the rod bearing orifice, we now have seen the ultimate pressure drop in an engine, compared to what we see on the gauge. Pressure/flow still adequate, but if we're going to obsess, 'adequate' won't do it
High viscosity oils make that pressure drop worse, like 40s, 50s will suffer the utmost pressure drop at the bearing. Counterintuitive to what most would think, a higher viscosity oil can easily increase bearing temperatures with a std clearance. Not only from the increased molecular friction that must be overcome, liberating only heat, but the flow rate across the bearing will be much reduced, again inhibiting cooling. And pressure/flow was already impeded before it entered the crank! NOW we can talk about 300 degree bearing exit temperatures- because with impaired bearing cooling, and increased drag, 300 degreeF exits would be easily obtained . I can promise you that with even a 20 grade, you will not see bearing temperatures in that range, precluding the supply oil from breaking down. Further to the point, SBC main and rod journals are well-sized, and a longer bearing has a higher surface speed, at the same crankshaft RPM, and higher bearing speeds enable a stable hydrodynamic wedge on low vis oil, comparable to a shorter bearing with a higher vis oil.
Notes:
-there is the effect of "slinging" within the crank that would contribute to oil flow. In reality, the contribution is insignificant and cannot compensate for prior flow deficiencies.
-short bearings/low RPMs (low bearing surface speed) and extreme loading does necessitate the usage of high viscosity such as an engine with diesel-like crankpin forces (turbo) combined with small sized bearings (such as a highly boosted Honda B-engine for instance with a 45mm crankpin).
[/small digression]
tl;dr
Pros-Cons to viscosity
Low Vis
Pros:
-better flow/supply, enabling better cooling and less stagnation in high stress areas
-less molecular friction, less heat generated
-less pressure/flow drop at the end of delivery system (rod bearings), again enabling better cooling
-less useless work (bypassing)
Cons:
-less durable film strength in localized areas
-less thermal stability, cannot stand being stagnated in high stress areas (which is counterintuitive to it's greater flow)
High Vis:
Pros:
-thicker film strength; stronger hydrodynamic wedge relative to force applied.
-greater thermal stability, can withstand stagnation in high stress areas better, (despite it's resistance to flow exasperating this condition in the first place)
Cons:
-resistance to flow reduces, well, flow. greater pressure/flow drop at end of delivery system (rod bearing)
-less flow means more bypassing, useless work robbing horsepower, liberating heat
-more molecular friction (drag) within the bearing; increased thermal load for no reason, both increaselocal and bulk temperatures
Belgian, I'm not going to tell you exactly what to do, I hope you can make the decision on your own, based on knowledge.
