Originally Posted By: CATERHAM
Not to mention when the oil is up to temperature the oil pump should not be in by-pass mode at all anyway. If it is the oil your running is too heavy.
The only working oil pump not going operating bypass at the mid-top of the rev range is one pumping air. OP says he's running a high volume unit anyway, which exasperates the issue at hand- it will probably begin bypassing just off idle. Oil being at operating temperature moderately raises the RPM that the bypass begins to operate, and with heavier oils, that RPM is quite low. CAT's if you really think a bypass shouldn't be opened under normal conditions then I'd pay you upwards of 10bucks to mechanically disable your bypass valve, fill your engine with operating temperature TGMO 0W20, and bounce off the limiter. Just stand clear of the oil filter, is all I ask
You've lost me.
The by-pass on my Porsche set at nominally 108 psi. My Caterham is at 93 psi. A track buddies Z-06 is 80 psi.
Running TGMO 0W-20 in my Caterham at maximum rev's with 95C oil temp's, OP is around 65 psi.
Running the spec' oil the Porsche and Corvette, as in all cars I know of, will have maximum oil pressure significantly below the the by-pass point at normal hot operating temp's.
The Porsche may be a little different than the SBC (and many other cars). 108psi is just a tad higher than most other vehicles on the road (50-64 psi) If we're talking about cars like Porsches, then you're right. An SBC is a little different. SBC with HV pump, mucho differento- lower bypass spring pressure, higher volume.
My KLZE is actually similar to your CATERHAM, I've been running Honda 0w20 in it and testing maximum pressures; I too top out around 65psi. Bypass spec is 80psi. The thing is, in the last third of the RPM range (5500+), pressure's stable @65 (hot). Imagine that?
Regular cars bypass a lot of the time. Example - A Toyota 4 cylinder with yet a shimmed bypass spring stabilized oil pressure at around 4800rpm (80psi) hot on 5w20. Caveat-it was the only S-engine equipped with a higher volume pump
and it was overdriven. Camry original parts.
The Mazda F-engines had the following specs:
1,000 RPM 21-36 psi
3,000 RPM 44-58 psi
Oil Pump Relief Pressure 43-57 psi
(hot values). 3000+RPM and it's bypassing HOT.
So I'm just saying man, one absolutely cannot assert that an oil is 'too thick' because there is bypassing occurring during hot operation.
I would also like to share a story of repeatedly spun bearings, cross drilled cranks and 50 grade oil. What happens in the end is not at all what you thought
