A little info on the changes made to the GM engine family for 2014 and up. The oil system has changed in a major way as from just a direct drive oil pump. Also in all my revolutions around the sun, it amazes me that people question the manufactures recommendations. Maybe they should stop recommending oils, no longer have a warranty and let everyone run what they want since they all know better from "all the years" they have done things in life without any issues.
Advanced Oiling System
The oiling system incorporates a new variable displacement two-stage vane-type oil pump that enables more efficient oil delivery, based on the engine’s operating conditions. Its dual-pressure control enables operation at a very efficient oil pressure at lower rpm, and then delivers higher pressure at higher engine speeds.
An oil control solenoid valve, controlled by the Engine Control Module (ECM), mounted to the oil pump provides two-stage functionality. The oil pump is mounted on the front of the engine block and driven directly by the crankshaft sprocket. The pump rotor and vanes rotate and draw oil from the oil pan sump through a pick-up screen and pipe. The oil is pressurized as it passes through the pump and is sent through the engine block lower oil gallery.
Pressurized oil is directed through the engine block lower oil gallery to the full-flow oil filter and then to the upper main oil galleries and the valve lifter oil manifold assembly.
An oil passage at camshaft bearing location permits oil flow into the center of the camshaft. Oil enters the camshaft, exiting at the front and into the camshaft position (CMP) actuator solenoid valve. The CMP valve spool position is controlled by the ECM and CMP magnet. When commanded by the ECM, the CMP magnet repositions the CMP actuator solenoid valve spool directing pressurized oil into the CMP actuator to control valve timing.
dexos 1™ Engine Oil
TIP: Failure to use the recommended engine oil and correct viscosity or its equivalent can result in engine damage not covered by the vehicle warranty.
The dexos1 specification was uniquely designed to complement the exacting requirements of GM’s advanced engine technology. The specification has gone through an extensive developmental and testing process. Only those oils displaying the dexos1 trademark and a registered trademark logo on the front label of the container meet the demanding performance requirements and stringent quality standards set forth in the dexos1 specification.
SAE 5W-30 is the required viscosity grade for the 4.3L engine.
SAE 0W-20 is the required viscosity grade for the 5.3L and 6.2L engines.
DO NOT use other viscosity grade oils such as SAE 10W-30, 10W-40, or 20W-50.
The engine oil with filter capacity has increased significantly from model year 2013 to model year 2014.
This also includes 2017 models as nothing has changed.
