09 ram 1500 replacement headlights.
Daughter 09 ram light harness is h13. The replacement lights are h11. Anyone know of a simply adapter to plug into the existing h13 harness to a .ale h11 connector to the bulb ...is there a h13 to h11 adapter or do I need to cut off h13 and replace with j11 female connectors? Thanks
Not sure what to think here. H11 bulbs have one filament. H13 bulbs have 2.
Do the replacement headlights have 2ea H11 bulbs?
Hi, no... just the 1 per side ans the turn signals...which are same as originals so nothing to modify there. Just the existing h13 harness needs to be h11 compatable.
I think you got wrong assembly and need to send it back.
1. Mopar says: "To ensure your headlamp assembly will fit and function correctly on your vehicle, you must purchase the same bulb style as your original equipment. Low beam bulb type may differ from high beam, daytime running lamp, and other accent lamp bulb type. Differences are noted in the catalog, where applicable."
2. I looked up a CAPA certified application by TYC and it specifies that it comes with an H13 bulb.
3. This tells me that MOPAR doesn't want you to change the wiring. You need to get a proper assembly that comes with H13 bulbs.
I’ve seen thousands of A/M headlamps and never seen a situation where the bulb had to be changed. Maybe if it’s a tuner part, but not when you’re installing a “correct” imitation part.
Contacted the vendor that assured me these were oem to my existing 09. Lie #1, told me I'd have to prove incompatibility before they would accept return. Gave them video footage, they said they couldn't verify I had not tampered with wiring harness and now blaming their part! Wow... I found correct set that even specifys h13 harness. Some vendors sure suck!! Ya'll be safe... gonna get REAL ... Real soon!!
  • Wow
Reactions: D60
