It would be good to do a bit of troubleshooting to know the pathway for oil loss.
As I'm sure you already know, the PCV system on that engine is a known contributor to oil consumption. But I think you've ruled that out.
If it's pistons/rings, then either coked up oil rings/piston drain holes or plain old engine wear is to blame. Either way, that is a mechanical problem and solvents or oil type is unlikely to fix it. If it's related to the turbo or PCV, that may be more easily addressed. However, failed turbochargers often result in great billowing clouds of embarrassing blue exhaust smoke.
http://karmakanix.com/knowledgebase...2-0t-oil-consumption-pcv-breather-valve/
Even so, it may not be a bad idea to switch oil types and viscosities. Maybe try the above suggestion of M1 high mileage 10W-40 at your next oil change. It's really a no cost bit of troubleshooting.
