CC: Visa
7
3
5
1
1
21
3
3763
20
1043
1221
10
14
3
45
20
43
2215
35
646
780
1
3
1
1043
21
46
3763
20
J.E: A slightly low viscosity was the only unusual finding in the first sample from this engine. The flashpoint
was fine, so we don't think the low viscosity was caused by fuel. If this oil were actually a 5W/20, then the
viscosity would be okay. Everything else looks great. Universal averages show typical wear from this type
of engine after about 5,265 miles use on the oil. Wear was generally lower here after a shorter oil run and
that's what we expect to find. No coolant was present and the low insolubles show good oil filtration. If any
problems exist, they don't show up here.
05/28/09
D78136 08 RAV4
(951) 769-2562
Gasoline (Unleaded)
Castrol Edge 5W/30
0 qts
6/12/2009
56-63
<0.1
>365
9.03
415
<0.5
0.0
0.0
0.2
0.0
<2.0
<0.6
[email protected]
9.1-11.3
55.9
Toyota 3.5L V-6 (2GR-FSE)
4,000 Miles
OIL
REPORT
LAB NUMBER: UNIT ID:
REPORT DATE:
CODE: PAYMENT:
MAKE/MODEL:
FUEL TYPE:
ADDITIONAL INFO:
OIL TYPE & GRADE:
OIL USE INTERVAL:
COMMENTS CLIENT UNIT
J.E. SEDLACEK PHONE:
FAX:
ALT PHONE:
EMAIL:
CLIENT ID: 26801
MANGANESE
Sample Date
ALUMINUM
CHROMIUM
IRON
COPPER
LEAD
TIN
MOLYBDENUM
NICKEL
SILVER
TITANIUM
POTASSIUM
BORON
SILICON
SODIUM
CALCIUM
MAGNESIUM
PHOSPHORUS
ZINC
BARIUM
MI/HR on Oil
MI/HR on Unit UNIVERSAL
AVERAGES
UNIT /
LOCATION
AVERAGES
Make Up Oil Added
ELEMENTS IN PARTS PER MILLION
Values
Should Be*
* THIS COLUMN APPLIES ONLY TO THE CURRENT SAMPLE
©COPYRIGHT BLACKSTONE LABORATORIES 2007 LIABILITY LIMITED TO COST OF ANALYSIS
416 E. PETTIT AVE. FORT WAYNE, IN 46806 (260) 744-2380 http://www.blackstone-labs.com
PROPERTIES
cSt Viscosity @ 100°C
SUS Viscosity @ 210°F
Flashpoint in °F
Fuel %
Antifreeze %
Water %
Insolubles %
TBN
TAN
ISO Code
15,000
4,000
