08 Forester N/A, Subaru 5W-30, 9600 miles OCI
Al
Elizabethtown, Pa
I think the report is great. The vehicle has 135K miles and had a head gasket job 8 months ago. One oil change was done before this run. I don't know how it could be better. I think I'll keep this beast.
Code:
Miles on oil 9600
Miles on unit 135,000
Makeup oil 3/4 quart
Al 3
Cr 0
Fe 5
Cu 1
Pb 0
Sn 0
Mo 132
B 39
Si 7
Na 4
K 3
Ca 1998
Mg 18
P 687
Zn 824
SUS (210F) 55.2 SUS
cSt. (100 C) 8.84 cSt.
Flashpoint 400F
Fuel < .5
Water 0.0
Insolubles % .2
Originally Posted By: Bandito440
Lookin' good.
Have you done the timing belt and water pump?
Yea + all the idlers, new seals, t-Stat, the short WP hose in there. Subarus (pre 2011) become needy after 100K miles.
Originally Posted By: Marco620
Is subaru 5w30 Synthetic? Good UOA : )
Yes. Its made by Idemitsu.
Originally Posted By: badtlc
It should be good with that much make up oil.
A quart (actually closer to 3/4) has very little effect in 10K miles.
Oh yes it does. That is 20-25% difference in numbers.
Actually its closer to 10%. If you were to replace that oil say in the first 100 miles it would be close to 0% and if you did it at the very end it would be about 20% so it turns out (math wise) with continuous use and replacement its right smack in the middle or 10%. Just saying.
Hopefully a better idea of what's happening.
Lookin' good.
What is a WP hose?
Originally Posted By: webfors
3/4 quart in ~10k miles on a ej25 is *excellent* IMO.
Great report!
-Dennis
Originally Posted By: Phishin
What is a WP hose?
The water pump has a short rubber discharge hose as I recall.
