wolfehunter
Did try the idle relearn a few times early on in this process but the car would usually stall a few times before coming up to temperature and completing the full process. And I remember turning the AC on per the relearn instructions and noticed that the rough idle went away while the AC was on. I did drive the car to work one day after that relearn attempt which was 20 miles round trip and check engine light came back on with no change to idle.
The idle air control unit is located right on the throttle body and I checked the resistance on it. It is 4.8 ohms. There are no screws or bolts holding on the black plastic looking cover that is over the IAC. Is there anything in there to clean? I see you can buy IAC gaskets for the unit but there is no actual valve to replace. Looking at all angles but surely missing something.
