Hey guys
I recently had the dealership change afm pressure relief in the oil pan due to low oil pressure and it fixed it and now 4,000 later The oil pressure in my opinion is lower then it was at 40 at cold start this morning and used to be about 45 psi at a cold start and now at warm to temp engine it is 33, 34, 35 Psi at 2,000 rpms and can get it up to 40 if I step on it about 3500 rpms And I have about 3,000 miles on the oil and used conventional Mobil 1. I do not know If that considered normal for an engine with 125,000 on it. I was going to drop oil pan and replace O ring and replace oil pressure sensor Before to see if that makes a difference before dropping pan Or do you think this is normal pressure and should not worry about it.
Thanks Jacob
Thanks Jacob
