Hi
I have a 07 gmc sierra 1500, this morning I started truck and it started squealing which it never did the day before but it did a lot colder that night 25 degrees it eventually went away at idle but as soon as I accelerated you could hear it in cab. the belt is new, tensioners new, water pump is new a couple days ago and it’s not leaking at all and dry and coolant level is still the same as when replaced and temp is good. I did notice when I replaced the water pump the power steering pump pulley had a little play in it and pulley sounded not normal but could that sqeal like this? sounds like a belt that needs to be replaced. The AC belt is new and tensioners are new
any advice?
if power steering pump needs replaced is there a step my step manual I can read?
any advice?
