06 Tribeca B9 with H6 engine, 161 k miles
va
Hi, I have happily run Rotella T6 5w-40 on my 04 Subaru Forester XT with EJ257. I now have the subject Subaru Tribeca with H6 3.0 Engine and I'd like to know if I should do the same.
I know nothing about consumption since I just picked it up but like the fact that I can get Rotella T-6 from Amazon cheaply and love the rebates.
I see some suggestions here and there, but I see a bit more opposition to using T-6 on this engine as opposed to the 2.5 EJ255 and EJ257.
Any ideas?
Thanks!
Thanks!
With that being said, why not the factory suggested 5w30 for better gas mileage? These things apparently get pretty poor gas mileage from the factory. I mean, I can see the 40w with the higher mileage though.
This is the same engine as the H4 in the Outback. I usually get lots of posts when I get a "new" vehicle.
Just one response?
I meant "H6". Any harm in using T6? I have been reading posts about T6 damaging cats. Probably an endless debate. Besides that, any other reason that I might not want to use T6 on this high mileage vehicle?
I mean it's dirt cheap with Amazon Prime and rebates. This engine take 6.7 quarts.
Gosh, I have become some sort of redheaded stepchild here. Anyways, I noticed a puff of blue smoke when starting the vehicle. I overfilled it accidentally after noticing that it was a bit low after purchasing it.
I had some Rotella T6 5W-40 laying around and installed it along with a Pure One oil Filter.
So this is a game changer for me. I am going to drive it long distance to see what sort of consumption I am getting.
I am *guessing* this is valve seals? I don't have time to run a compression test right now.
Would you all try Mobil 1 High Mileage maybe? No one knows much about the H6 Subaru?
Thanks
Thanks
How did it work out for you? I have an 06 one also that I've just been using 5w30, but I'm curious.
