Originally Posted By: ericthepig
Trouble - I've got a coolant leak. Chked the level (while hot) just now - had to add about 12 oz water to get back to full line. Is this a head gasket problem? Is this expensive? Can I limp it along by chging the oil more often and keep the coolant full?
They weren't sure if it was from the oil or the head gasket. I'd try using oil that doesn't contain sodium and seeing how the level is. Also inspect the coolant hoses in the car, thermostat & thermostat housing seals and the water pump seal, if nothing is leaking there then it's most likely the head gasket.
Head gasket replacements are expensive. Around 500-600 from an independent mechanic to about $1,000 from a dealer (in my area). It is not a difficult DIY job though (for non-catastrophic failures, and yours is not a catastrophic failure). The reason it costs a lot is because it takes a lot of time. Not sure what kind of tools you have but you'd need an impact wrench, impact hex bits (I twisted off an impact rated hex bit on an engine that head gasket blew due to overheating from a catastrophic cooling system failure), and uh... a bunch of degreaser
. Head gasket will cost you about $40. You'd also want to replace the cylinder head screws as they stretch and should not be re-used. Those will also cost you about $40.
You can limp the car around, sometimes head gasket leaks progress so slowly that it's almost irrelevant. Some go from leaking to catastrophic failure. It's really impossible to diagnose which of those without seeing the head gasket, but I'd record the coolant use and see if it increases. If it's increasing, then replace that gasket ASAP. If you plan on keeping the car though, it is my recommendation to get the head gasket fixed if that is the problem.
Edit: I forgot to say you'd also need a torque wrench to properly torque the bolts when reassembling.
