- Joined
- Apr 23, 2022
- Messages
- 10
Posting for my brother's car. 06 Elantra, 199,xxx miles, automatic. Recently had it stalling at lower speeds. Tried replacing the filter in the pump, which didn't fix it. Only 2 codes popped up, P0304 and P0453, neither of which I've known to prevent starting. About to try plugs, since it really needs new ones anyway.
With key on and engine off, you can hear the pump priming. You can hear the pump trying to send fuel while the other person tries starting. Iirc, that rules out the CKP.
So far, we've ruled out the timing belt (still there, still mounted properly and it spins when the engine is cranked) and the pump itself. Removed plugs and cranked, all of which had spark, although it was weak. Not sure if i smelled any gas from the engine while the plugs were out and the engine was cranking.
I'm about to head over there and remove the fuel rail, leaving the injectors attached to see if fuel sprays out. Either that, or I'll look for a stethoscope when i stop for plugs.
I'm starting to think it may be the fuel pressure regulator. If it is, at least it's easy to get to. Under the rear seat, attached to the fuel pump.
