Here's the UOA for the wifes car using same oil and filter and similar type of miles as my F150. It's interesting to see that the Honda is better on the oil than the F150.
Blackstone Report:
No problems showed up in this initial sample from your Honda engine. All wear read right around averages for this type of engine, which is a very good indication of normal wearing parts. The universal averages show normal wear from the Honda 2.4L after about 6100 miles on the oil. Insolubles were low at 0.2%, showing excellent oil filtration. No fuel dilution or anti-freeze was found. Silicon was okay at 12 ppm, so your air filtration is still getting the job done. The TBN read 3.8, still active additive left. This engine is doing very well. Try 5000 miles next.
Code:
2006 Honda Accord 2.4L
OIL Motorcraft blend 5w20
Filer: Pure1
MILES IN USE 4065
MILES 25,315
SAMPLE TAKEN 5/29/07
ALUMINUM 3
CHROMIUM 0
IRON 5
COPPER 4
LEAD 0
TIN 1
MOLYBDENUM 35
NICKEL 0
MANGANESE 0
SILVER 0
TITANIUM 0
POTASSIUM 0
BORON 194
SILICON 12
SODIUM 3
CALCIUM 1949
MAGNESIUM 7
PHOSPHORUS 687
ZINC 822
BARIUM 0
INSOLUBLES 0.2
WATER 0
FLASHPOINT ºF 375
SUS VIS 210ºF 49.1
cSt @ 212ºF n/a
Blackstone Report:
Code:
Filer: Pure1
MILES IN USE 4065
MILES 25,315
ALUMINUM 3
CHROMIUM 0
IRON 5
COPPER 4
LEAD 0
TIN 1
MOLYBDENUM 35
NICKEL 0
MANGANESE 0
SILVER 0
TITANIUM 0
POTASSIUM 0
BORON 194
SILICON 12
SODIUM 3
CALCIUM 1949
MAGNESIUM 7
PHOSPHORUS 687
ZINC 822
BARIUM 0
INSOLUBLES 0.2
WATER 0
FLASHPOINT ºF 375
SUS VIS 210ºF 49.1
cSt @ 212ºF n/a
