I am new to transmissions and I have some questions. I have a 2005 Ranger FX4. I am sitting at 60K miles right now and the ATF was changed by the dealership at 30K miles. I assume they used whatever was the cheapest grade of Motorcraft ATF that met the specs.
I recently checked the ATF and the level is good as well as the color. Do I need to continue 30K mile change intervals as a general rule?
Also, what ATF should I use if I want synthetic? (No Amsoil) I looked into Mobil 1 and it was $7.99 at O'reily's. Are there any other good synthetics out there that are cheaper. Does anyone have any experience with Motorcraft's synthetic blend ATF?
I need a MERCON V equilivlant and I need 11 quarts of it.
