Here's what I'd use...maximum protection in the warranty-approved 5w-30 grade while keeping the engine super-clean as well.quote:
Originally posted by moontan:
hi all. i have a 04 prerunner w/ the 3.4 v6 that specifies 5w/30 oil. i think 10w/30 would be better for all around use in socal. what does the collective think? dino base? synth? different wt.?
That Amsoil oil is not "warranty approved" because it is neither ILSAC GF-3 nor API-SL licensed.quote:
Originally posted by Jelly:
Here's what I'd use...maximum protection in the warranty-approved 5w-30 grade while keeping the engine super-clean as well. Make sure to use a high-quality oil and air filter as well...
While it is not a friction-modified GF-3 oil, it is indeed API SL certified...quote:
Ken
I could be wrong, but I don't believe the Toyota 3.4 tends to shear the oil.quote:
Originally posted by TooManyWheels:
Since the 3.4 tends to shear the oil, most of us on this board with that engine are running synthetics, and in 10w-30, which because of fewer viscosity improvers, has less tendency to shear. Off the top of my head, I know we have UOAs from Mobil 1, Amzoil, Schaeffer's, and probably a couple of dino's. Also pay close attention to the interval, due to the shearing issue.
The 3.4L has gear driven intake cams but doesn't seem to shear the oil like some other engines. I've done 2 UOA's on mine and seen no real shearing.quote:
I used Mobil 1 10W30 and Schaeffer's #703 10W30 on a 3.4 for 100k. It ran flawlessly when I sold it. Still runs great according to the current owner.
