04 Silverado code c0267
I'm currently getting code C0267 low brake fluid detected. I don't have a low fluid sensor installed through the master cylinder reservoir. Has anybody seen this before? I have cleared the code and it keeps coming back immediately. I performed a brake fluid flush after the code started to appear all the time (it needed it, factory fill was nasty). I'm also not sure if I need to specially bleed the abs system somehow.
That's not what DTC C0267 means.....
The EBCM detects any of the following conditions:
*An open or shorted pump motor
*An open or shorted pump motor driver circuit
*A seized pump motor
IF the abs pump motor isn't running all the time...Do the following...
1. Check ground G110 to be tight and clean. Ground 110 is under the driver door on the frame.
2. If the ground is OK, replace the ABS pump motor and module.
Thanks for the info. I'm going off what my blue driver is reporting to me.
