'04 Honda ST 1300 Motr.Cycle,Factory Fill, 280 miles
Houston,TX
2004 Honda ST 1300 Motor Cycle Factory Fill, 280 Miles 6/15/04 All Filters Stock Aluminum 10 Chromium 1 Iron 26 Copper 12 Lead 2 Tin 2 Molybdenum 301 Nickel 0 Manganese 2 Silver 0 Titanium 0 Potassium 4 Boron 55 Silicon 21 Sodium 9 Calcium 640 Magnesium 382 Phosphorus 981 Zinc 964 Barium 17 SUS Vis @210f 55.4 Flashpoint 395f Blackstone says..."...The wear is from new parts wearing in, & the silicon is from sealers and sand-casted parts. Sodium & potassium are also found as a factory leftover in new engines. The viscosity was in the upper 20W to lower 30W range. The TBN read 4.8. Try running 1000 miles on the next oil & resample.
South
Charlie, Do you have the fuel % or insoluble % numbers? Moly number sure is interesting. Good olde shearing Honda oil unless fuel is thinning it. Looks like your bike is wearing in fine. Maybe look to moving on to some better oil after break-in is a done deal. The Honda filter is awesome!
