Hi all...
(...don't know what happened to the post I was working on but it disappeared...let's try this again...if you see an incomplete post from me ignore it!)
I just received my first-ever UOA from Blackstone on my 2003 PT Cruiser. I bought the car new and it has been a great vehicle...no problems in the 24,000 miles I've accumulated. I'm more than happy with this UOA and plan to continue my regimen. I replaced the air filter at 20,000 miles with a new Fram unit and the PCV as well. This car sees 15 mile daily commutes to work which is mostly stop and go. I'm even happier with these results considering how the car is driven. This interval is for a 3 month interval so these are mostly cold winter miles here in Michigan. I'm easy on the car and careful to warm it up slowly and avoid prolonged idling...have a look and let me know your thoughts.
Vehicle: 2003 Chrysler PT Cruiser
Engine: 2.4l DOHC 4 cyl.
Oil Type: Schaeffers 5/30 Blend
Additives: Lube Control and Fuel Power
Element: This Test/UA
Aluminum: 2/4
Chromium: 1/1
Iron; 5/18
Copper: 1/7
Lead: 0/2
Tin: 1/1
Moly: 95/18
Nickel: 0/0
Manganese: 0/1
Silver: 0/1
Titanium: 0/0
Potassium: 0/0
Boron: 3/40
Silicon: 11/15
Sodium: 2/4
Calcium: 1629/1131
Magnesium: 3/620
Phosphorus: 632/826
Zinc: 788/1049
Barium: 0/7
Properties:
SUS Vis. @ 210 F.: 60.2/53-62
Flash: 410/>355
Fuel: Antifreeze: 0/0
Water: 0/0
Insolubles: 0.4/ TBN: 1.5-Blackstone method
Blackstone commented that the results looked great but noted the borderline TBN. Although they said I might eke a few more miles out of my next interval I think I'll hold pat at about 4,000 miles.
Despite an additive pack that isn't overly impressive to the eye, this oil seems to return consistently good results and I've used it in my last three vehicles. I have a 3.8 GM V6 with about 90k miles that gets the same treatment...may do a UOA on that to see what it looks like...appreciate your comments!
Aluminum: 2/4
Chromium: 1/1
Iron; 5/18
Copper: 1/7
Lead: 0/2
Tin: 1/1
Moly: 95/18
Nickel: 0/0
Manganese: 0/1
Silver: 0/1
Titanium: 0/0
Potassium: 0/0
Boron: 3/40
Silicon: 11/15
Sodium: 2/4
Calcium: 1629/1131
Magnesium: 3/620
Phosphorus: 632/826
Zinc: 788/1049
Barium: 0/7
Properties:
Flash: 410/>355
Water: 0/0
