- Messages
- 284
- Location
- Charlotte, NC
what can you do to keep the rear tires from spinning and the rear end from slifdding around in the snow.......should i try adding weight or what??
quote:Is your rear end limited slip or a one legger? I run four bags of play sand behind the rear axle in my '95 F150. Never had any problem with steering. The sand may come in handy if you get stuck. Throw some under the spinning tire(s). Got the wife's Aerostar one legger out that way last winter.
Originally posted by crimsontide: what can you do to keep the rear tires from spinning and the rear end from slifdding around in the snow.......should i try adding weight or what??
quote:And there's your problem...switch to some better tires and you'll notice a world of difference!
Originally posted by crimsontide: the tires are the factory bf goodrich radial long trail t/a
