I decided on the Left Outside Frame rail location for the Motorguard Oil bypass filter install. I turn the wheel to the full right and the filter is easily within reach to service. I mocked the filter up and used a quick clamp to hold it (bracket & filter) in placed and drilled three holes in the frame rail. The lines will route forward and curl up and over the front of the frame rail then stay right on top of the rail the short distance to the PermaCool adapter at the oil filter location.
Question - Would the Motorguard need to be truely vertical as it is clamped ?
I installed the TP roll after I bolted it up to be sure I could. A 3/4" or 1" block spacer under the bracket would allow the unit to sit out a bit from the frame and be truely vertical and have room to change the TP roll without difficulty.
I guess I would rather have the filter leaning toward the frame rail side rather than away in the event the bolts were to ever loosen. Loctite plus the lockwashers should secure it. I will run it a bit before deciding.
More Pics to follow as I finish this one and go on to the Transmission setup.
PermaCool Adapter to fit the Ford
Here is the Transmission Setup - to be installed.
